Install the XProtect Smart Client user assistance for offline use
If you want access to the XProtect Smart Client user assistance, you can download and install the XProtect Smart Client user assistance in various languages. Each language has its own language package, which you install separately. The user assistance also explains how to use XProtect Smart Client functionality from any XProtect extensions your organization might have.
Contact your reseller for a zip file with the user assistance files and guidance on installing them.
To download and install the user assistance:
From the
Language packageslist below, select a language to download and save a .zip file with a language package of the user assistance.If you, for example, run XProtect Smart Client in German, you should download the German .zip file. If you run XProtect Smart Client in a language that doesn’t have a corresponding user assistance language package, download the English language package. You can download as many language packages as you want.
From the
Checksums (SHA256)list below, use the checksum that corresponds to the language pack .zip file you downloaded to validate that the .zip file is authentic and has not been tampered with. Use a checksum tool, such as Windows certUtil -hashfile, to read and compare the SHA256 encrypted checksum values in the list below.On the computer where XProtect Smart Client is installed, unzip the .zip file directly to the HtmlHelp folder. The default location of the HtmlHelp folder is
\\Program Files\Milestone\XProtect Smart Client\HtmlHelp\.Note
Keep the language files in their language folders. For example, the English files must be in the
en-USfolder.
Language packages
Language folder | Language |
ar-SA | |
cs-CZ | |
da-DK | |
de-DE | |
en-US | |
es-ES | |
fr-FR | |
it-IT | |
ja-JP | |
ko-KR | |
nl-NL | |
pl-PL | |
pt-BR | |
ru-RU | |
sv-SE | |
tr-TR | |
zh-CN | |
zh-TW |
Checksums (SHA256)
Validate the ZIP file downloads using SHA256 checksum validation. The checksum values are located in this file.
