Export locked video evidence
When you export evidence locks, also the data from devices related to the cameras is included in the export.
Switch to playback mode.
On the workspace toolbar in the upper-right corner, click Evidence lock and select View.
Select an evidence lock and click Add to export list.
Continue with the export process. See Adjusting export settings and Create an export.
