Edit evidence locks
Depending on your user permissions, you can edit evidence locks, for example time interval, cameras, and how long to keep the evidence lock.
Switch to playback mode.
In the upper the right corner, click Evidence lock and select View, or select Evidence lock on the global toolbar.
Select an evidence lock and click Details. A window appears.
To make the interval of the evidence lock shorter or longer, use the Evidence lock interval start and Evidence lock interval end fields.
To change the time that the evidence lock is valid for, select a value in the Keep evidence lock for list.
When done, click Update.
A window shows if the update was successful. Click Details to see what went well and what did not. See also Evidence lock status messages.
