Defined values of XProtect Smart Client settings
You can customize XProtect Smart Client in many ways.
Within the XProtect Smart Client settings, you can change parts of XProtect Smart Client’s behavior and which functionality are available to you.
The system administrator might set default values for certain or all settings or delegate the configuration responsibility to you. You might have the right to modify the default values for specific settings, though in some cases, you’re not allowed to make any changes.
You can change the settings anytime, but changing some settings may require you to restart XProtect Smart Client.
The settings you define are saved in your local user account on your computer.
Here are a few examples of XProtect Smart Client settings:
Show/hide bounding boxes on video.
Show/hide audio recordings on the timeline tracks in the main timeline.
The default path for snapshots.
Restore your views from last login.
You can find all XProtect Smart Client settings here:
On the global toolbar, select the Settings and more menu, and then select Settings.
