Change field of view and direction of camera
Once the camera has been added to the smart map, you can change field of view and direction by adjusting the camera icon.
Tip
If you are zoomed out on the map, you may have to zoom in until the field of view is displayed.
Select the view that contains the smart map that you want to work with.
Click Setup to edit the camera icon.
Click the camera icon.
Use the rotate handle to point the camera in the right direction.
To adjust the width, length, and angle of the field of view, click and drag the handles at the front edge of the field of view.
To save your changes, click Setup to exit setup mode.
