The main timeline and edge retrieval
Version2025r3
LanguageEnglish
If you select a camera with edge storage, the light and medium gray colors on the timeline tracks show whether the recordings on an edge storage are retrieved to your local recording server:
  • The light gray color with the legend Unknown indicates that the recordings are not retrieved. Before a retrieval attempt, you can’t see if there are recordings to retrieve from the edge storage.
  • The medium gray color with the legend Data requested indicates that retrieval is in process.
    Timeline. Below the timeline are a slider and buttons to play, pause, and to select time.
When the recordings are retrieved, the timeline tracks use the same colors as for all your recordings. See Color legend.
