Recordings from edge storage and XProtect Interconnect
Version2025r3
LanguageEnglish
There are two types of cameras with edge storage:
  • Cameras with memory cards on which the recordings are saved.
  • Interconnected cameras that are part of another XProtect VMS installation and that you have access to through XProtect Interconnectâ„¢.
When you have the necessary user permissions, you can manually retrieve recordings from cameras with edge storage. Retrieval of recordings can also happen automatically through rules defined by your XProtect VMS administrator.
