The context-specific timelines
Version2025r3
LanguageEnglish
There are several timelines that help you investigate and navigate your recordings in specific contexts.
These context-specific timelines often only have one timeline track and a few to none of the controls available in the main timeline. But when they have timeline controls, they work the same way as the ones on the main timeline.
Timeline
Available from
Purpose
Learn more
Independent playback
All views tabs
While viewing live video, you can decide to view and go back and forth in the recordings from one of the cameras in your view.
View recorded video independently of the main timeline
Bookmark
All views tabs
If a sequence of recordings has a bookmark, you can easily find and go to this sequence.
Bookmark window
Search
The Search tab
If you have searched for something on the Search tab, the search timeline gives you an overview of recordings matching your search. You can select the different found recordings to view them.
The search timeline on the Search tab
Export
The Export tab
If you have selected recordings for export, you can go back and forth in the selected recordings and change the start and end times of the export.
Creating video evidence
