Bookmark window
Version2025r3
LanguageEnglish
The Bookmark window appears only when you have enabled detailed bookmarks. See Enable detailed bookmarks.
The layout of the bookmark window changes depending on where you are in XProtect Smart Client, and if you are adding one or multiple bookmarks. Click below to see images of the window.
Fields in the Bookmark window.
Name
Description
Bookmark ID
A number that automatically is assigned to the bookmark.
Added by
The person who created the bookmark.
The bookmark timeline
The time selection brackets shows the start and end time of the bookmarked sequence. To change the start and end time, drag the brackets.
Timeline in XProtect Smart Client.
Headline
Specify a headline containing a maximum of 50 characters.
Apply headline to all in list
Note
Only visible if you are creating multiple bookmarks.
Click the text to use the same headline for all bookmarks.
Description
Lets you specify a description.
Apply description to all in list
Note
Click the text to use the same description for all bookmarks.
