Select a fixed live stream
Version2025r3
LanguageEnglish
If your system administrator has set up camera to send multiple streams, you can choose a live stream that uses less bandwidth.
  1. On the Views pane, select the view and the camera view item to replace.
  2. On the Properties pane, expand the Live stream list and select your preferred live stream option.
    Tip
    If your XProtect VMS uses adaptive streaming, select Default.
