Only refresh live streams with motion
Version2025r3
LanguageEnglish
To reduce network bandwidth and CPU usage, you can configure XProtect Smart Client to refresh a camera view item only when motion is detected. When there is no motion, a still image from the latest detected motion is shown with a gray overlay and the message No motion.
This setting can significantly reduce your computer’s CPU usage, depending on the motion detection sensitivity configured by your system administrator.
  1. Select the view and the camera view item to refresh only when there’s motion.
  2. On the Properties pane, select Update on motion.
