Search in exported video
Version2025r3
LanguageEnglish
On the Search tab, you can search the recordings included in the export, for example if you want to search a subset of the cameras.
You can search for recordings, motion, and bookmarks.
Search tab in XProtect Smart Client – Player. The different areas, such as buttons and views, are highlighted and numbered.
Number
Description
1
The time span is set automatically based on the export time span. You can define your own time span, for example Custom interval.
2
Add the cameras that you want to search.
3
Specify what to search for, for example Motion. You can combine search categories.
4
Review the list of search results. Scroll to view the next or previous search results.
5
Use the Thumbnail size slider to make the thumbnail images smaller or bigger.
6
Play back video from the search results.
7
Take further action based on your search results, for example create PDF reports to share or print evidence. The action bar appears when you select the blue check box inside the search results.
