Re-export video
Version2025r3
LanguageEnglish
You can only re-export video if the organization that shared the exported video with you has allowed it.
If you can re-export, you can export all or less video than you have received, for example, only 1 minute of the video and only the video from one of the cameras.
If the organization that shared the exported video has allowed it, you can also export it in media player format (AVI and MKV) and as still images.
  1. In the Export list, select Add item to add the cameras with the video sequences you want to export.
  2. If you want to export a shorter video duration than you have received, drag the time selection brackets for each camera to select a new start and end time for the export.
  3. Select a format for the export.
  4. Select Create export and select where to save the export.
