Listen to audio from your smart map
Version2025r3
LanguageEnglish
If any microphones are added to your smart map, you can listen to audio from one microphone at a time in live mode.
  1. Select your smart map.
  2. Find the microphone on the map.
  3. Double-click the microphone to mute or unmute it.
    You can also right-click the microphone and select Mute microphone or Unmute.
