View video in any view with a hotspot but no smart map
Version2025r3
LanguageEnglish
If you have a view with a hotspot view item, you can view the video from cameras on a smart map in the hotspot view item, even if they are in different views.
When you select a camera on the smart map in one view, its video is displayed in the hotspot view of another view.
  1. On the Views pane, right-click the view with the hotspot.
  2. Select Send view to and select a display option, for example, Floating window.
  3. Arrange the views with the hotspot and the smart map on your monitor or monitors so you can see both.
  4. Find the cameras on the smart map.
  5. Select the cameras. When you select a camera, its video is displayed in the hotspot view item.
