Delete floor plans on levels (Smart Map)
Version2025r3
LanguageEnglish
If a floor plan on a level inside a building has changed, you may need to replace the custom overlay illustrating the floor plan. Milestone recommends that you delete the old floor plan, before adding a new one.
Steps:
  1. Navigate to the building on your smart map. If necessary, zoom in.
  2. Select the building. A pane appears on the right-hand side showing you the levels of the building.
  3. On the workspace toolbar, select Setup.
  4. Select the level where the custom overlay is.
  5. Right-click anywhere on the custom overlay and select Delete custom overlay.
  6. Select Setup again to exit setup mode and save your changes.
Tip
To edit the position or size of the floor plan, right-click the custom overlay and select Edit position. Now you can move, rotate, and change the size of the custom overlay.
