Add devices to buildings (Smart Map)
Version2025r3
LanguageEnglish
After creating a building and adding levels, you can add devices to the building. If you've specified a default level, the devices are associated with it. If not, the devices are associated with the first level. You can change the level and associate the device with any of the levels in the building.
Steps:
  1. Go to the building on your smart map. Zoom in if needed.
  2. On the workspace toolbar, select Setup.
  3. To add a device, click its icon.
    Example: in the case of a camera, click SC_MapS_AddCamera_icon.png Add a camera.
  4. Click again on the location to position the device. A window is displayed.
  5. Select the device and click OK. For each device to add, repeat steps 3-5.
  6. To associate a device with one or more levels, right-click the device and select the required levels.
  7. Select Setup again to exit setup mode and save your changes.
Note
If you haven't selected any level, the device is visible on all levels.
