Add or edit bookmarks
Version2025r3
LanguageEnglish
You can add bookmarks to live and recorded video. If you have enabled detailed bookmarks, you can give the bookmark a name and a description. You can even adjust the time span. Later, you can find and edit the bookmark details.
Steps:
  1. Select the required camera in the view.
  2. Click the bookmark icon SC_CameraToolbar_AddBookmark_icon.png. With details enabled, the Bookmark window appears where you can add a detailed description of the incident.
  3. Enter a name for the bookmark.
  4. The default length of a bookmarked sequence is determined on the surveillance system server, but you can change this by dragging the start and end time brackets.
  5. (optional) Describe the incident.
  6. Click OK.
Tip
To find and edit the bookmark later, go to the Search tab and search for bookmarks. See Search for bookmarks.
