XProtect Remote Manager
Schedule a report
LanguageEnglish
Use scheduled reports to receive insights at regular intervals automatically. You choose the report type, the metrics to include, and when the report should run. This helps you stay informed about system health and performance without generating reports manually.
To schedule a report:
  1. On the Reports page, click Schedule report.
  2. Select the report type.
  3. Specify the name and add an optional description.
  4. Select the sites you want to get data from.
  5. Select the type of details you want to include. Each category appears as a separate column in the report.
  6. Select the reporting period.
  7. Select the export format (PDF or CSV).
  8. Set when the report should run.
  9. Select if you want to receive the report by email. The report is sent to the email address you use to sign in to XProtect Remote Manager.
  10. Select Schedule report to save the schedule, or Generate to create the report immediately.
The report appears in the Reports list.
