About reporting in XProtect Remote Manager
Reporting in XProtect Remote Manager gives you clear insights into system health, performance, and configuration across your XProtect deployments. It helps you understand how your system operates and where attention is needed. It also replaces manual reporting processes and unifies data that was previously spread across different sources.
You can generate the following report types:
On-demand reports give you instant insights. You create them manually when you need up-to-date information for a selected period.
Scheduled reports run automatically at the times you choose. They help you maintain regular system oversight and support routine reviews.
Reporting supports a wide range of data to help you diagnose issues quickly and provides decision-makers with clear, accessible information for planning and operations. The report types XProtect Remote Manager supports are:
Recording server retention. See Generate a recording server retention report.
Recording server uptime. See Generate a recording server uptime report.
Service details report. See Generate a service details report.
Device inventory. See Generate a device and device component inventory report.
Device component inventory. Generate a device and device component inventory report.
Storage details.
System events. See Generate a system events report.
Archive details.
Camera uptime report.
Recording server CPU usage.
