Create an alert
Alert notifications are sent to your registered email address and any additional recipients that you add to the alert.
You can only create alert profiles for a site that is online.
To create an alert:
On the Home page, click the site you want to create an alert for to open the Site Health page.
On the Site Health page, click Alert configuration in the left menu to open the Alert configuration page.
On the Alert configuration page, click Create alert to open the Create a new alert page.
On the Create a new alert page, create the alert properties and add recipients. See Alert properties.
By default, the alert is automatically enabled when you create it. If you want to disable the alert, you must manually do so. See Enable or disable an alert.
