XProtect Remote Manager
Connect a VMS installation to XProtect Remote Manager
LanguageEnglish
To monitor and manage your VMS installation remotely, you must add it as a site in XProtect Remote Manager.
A site is a VMS installation where the management server and related VMS components run on one or more hosts and can cover multiple physical locations. When you add a site, it becomes visible to all users in your organization.
To connect to XProtect Remote Manager, you must:
  1. Add a site in XProtect Remote Manager to generate a one-time key. See Add a site.
    Note
    The one-time key is valid for 24 hours. If it has expired, you can generate a new key from the home page of XProtect Remote Manager.
  2. Install using the one-time key from XProtect Remote Manager. See Install XProtect Cloud Connector.
After you have connected your site successfully, the XProtect VMS installation starts reporting states to XProtect Remote Manager.
