XProtect on AWS BYOL
Get the EC2 Instance ID
LanguageEnglish
You need the address of the EC2 instance to connect to your XProtect VMS installation.
  1. To open the AWS CloudFormation console, go to https://console.aws.amazon.com/cloudformation/.
  2. Select the XProtect CloudFormation stack that you created. It is identified by the Stack name that you specified during configuration.
  3. In the Resources tab, you will see all the stack elements that were created by the XProtect CloudFormation template. Select the Physical ID link that corresponds to the EC2 instance.
