XProtect on AWS BYOL
File system details for FSx
When you create an FSx file share, you specify the file system details.
File system details
Parameter
Description
File system name - optional
Specify a name for use in the AWS Management console.
Deployment type
Select Availability Zone (AZ). Single-AZ or Multi-AZ for redundancy.
Note
Single-AZ has a 30-minute weekly maintenance window that you can schedule.
Storage type
Milestone recommends selecting HDD storage type for archiving.
Storage capacity
Specify the size of your FSx share.
Throughput capacity
Select Specify throughput capacity to meet your throughput requirements.
Note
When you select a higher throughput capacity, you increase the cost of running your FSx share.
Network & security
Parameter
Description
Virtual Private Cloud (VPC)
Select the VPC where you have deployed your EC2 instance that is running your XProtect system.
VPC Security Groups
Specify a security group to associate with your file system's network interface.
Note
To allow access to the VPC, update the inbound and outbound rules of the selected security group. See Step 1: Create your file system.
Preferred subnet
You must select the same subnet as your EC2 instance running your XProtect system.
Standby subnet
Select a relevant standby subnet.
Windows authentication
Parameter
Description
Choose an Active Directory to provide user authentication and access control for your file system
Select the Microsoft Active Directory to use.
Encryption
Parameter
Description
Encryption key
Select your AWS Key Management Service (KMS) encryption key.
Backup and maintenance
Parameter
Description
Daily automatic backup window
Select No preference.
Automatic backup retention period
Set it to 1 days.
Weekly maintenance window
Choose Select start time for 30-minute weekly maintenance window and specify the start time of the maintenance window.
Important
Specify the start time so that the maintenance window does not overlap with your XProtect system archiving schedule.
Tags
Add tags that follow your tagging strategy.
