Export and download video from an investigation
In XProtect Mobile, you can export video recordings directly from saved investigations and download the export packages to your mobile device for archiving or sharing.
Before you begin
Make sure you have the Export permissions granted in the VMS.
Your system administrator must enable investigations on the Mobile Server and allow at least one export format (XProtect, MKV, or AVI).
Prepare and download the investigation
Go to the Investigations tab and select the investigation that you want to download.
Note
If another user has already prepared the export package for the investigation in XProtect Web Client or on another mobile device (connected to the same server), you can download the export package right away.
Tap the export format you want to use. For more details about file size considerations and playback options, see Formats for export packages.
To include audio streams in the package, select Include audio in the package. This option is disabled if the cameras do not have an associated audio source.
Tap Prepare (Android:
, iOS:
) next to the selected format. You do not need to stay on this screen while the package is being prepared. Note
The estimated file size displayed in the app prior to export is an approximation. The actual downloaded size may differ due to packaging, compression, and metadata.
When the package is ready, tap the Download (Android:
, iOS:
). You can leave the app during the download.When the download is complete, you’ll receive a device notification. For iOS, you’ll be asked where to save the .zip file.
To open or share the downloaded .zip package, on:
iOS: Open the
Filesapp and go to the folder where you saved the download.Android: Open your device's file manager to locate the downloaded file. If your standard file manager does not support .zip files, install a file manager or app that can extract .zip files.
Delete an export package
You delete an export package from an investigation by tapping the Delete (Android:
, iOS:
When you delete an export package:
The prepared package is removed from the Mobile Server.
Any packages already downloaded to your mobile device are not affected.
As long as the recorded footage is available on the Mobile Server, you can prepare and download a new export package at any time.
