XProtect Mobile client
Picture-in-picture
Version2025r3
LanguageEnglish
Using picture-in-picture in playback mode
If you see something that you want to investigate, but you don't want to stop observing the current situation, you can display live video using picture-in-picture (PiP) and play back video at the same time.
  1. Switch from live mode to playback mode by tapping MobC_Android_Playback_icon_I.png (Android) or MobC_iOS_Playback_icon_I.png (iOS).
  2. Depending on the operating system on your device:
    • Android - Tap MobC_Android_PiP_icon_I.png.
    • iOS - Tap MobC_iOS_PiP_icon_I.png.
    Note
    Incoming audio is not available in PiP when you use the feature while you view video recordings.
    Note
    To move the PiP window, tap and hold, and drag the PiP window to the preferred place on the screen.
Return to live video
To view the live video in full screen:
  • Double-tap the PiP window.
  • Tap MobC_Android_Back-to-live_icon_I.png (Android) or MobC_iOS_Back-to-live_icon_I.png (iOS).
Using background picture-in-picture
For Android users
To continue viewing live video, while you browse other content on your mobile device:
  1. Minimize the app. The picture-in-picture (PiP) window displays at the bottom-right corner of the screen. Double-tap the PiP window to enlarge it.
    Note
  2. To use the PiP action buttons, tap the PiP window. Options:
    • To enable or disable the background picture-in-picture, tap MobC_Android_PiP_Settings_icon_I.png.
    • To add a bookmark, tap MobC_Android_Bookmarks_icon_I.png.
    • To return to full screen, tap MobC_Android_PiP_Fullscreen_icon_I.png.
    • To close the PiP window, tap MobC_Android_iOS_PiP_Close_icon_I.png.
