Installing XProtect Mobile server components
This information is primarily for system administrators.
You can install the XProtect Mobile server in all XProtect products.
To get the most out of XProtect Mobile, make sure that you're using the latest version of your VMS product. Information about the products is available on the Milestone website (https://www.milestonesys.com/products/software/xprotect-comparison/).
You can also download the XProtect Mobile server for free from the download page on the Milestone website (https://www.milestonesys.com/download/).
Where to install the XProtect Mobile server component
Install the XProtect Mobile server component on the computer that runs your surveillance system or on a dedicated computer.
If you plan to have more than ten cameras in your system showing video simultaneously, Milestone recommends that you install XProtect Mobile server on a dedicated computer.
You can install the XProtect Mobile server in various ways:
XProtect product | Installation on the same computer as the VMS | Installation on a dedicated computer |
Complete a Single Computer installation of the XProtect VMS software. This installation includes the XProtect Mobile server. | Run the separate XProtect Mobile server installer. |
Installing the XProtect Mobile plug-in component
You should install the XProtect Mobile plug-in on all computers that run the Management Client:
Run the XProtect Mobile installer.
Choose a Custom installation and select the plug-in (32-bit or 64-bit). It is safe to install both.
Restart Management Client.
Operating systems
XProtect Mobile supports the following operating systems for mobile devices:
Operating system | Devices |
Android 13.0 or higher | Smartphones and tablets with Android installed |
iOS 18.0 or higher | iPhones and iPads |
