XProtect Mobile client
Install XProtect Mobile on a mobile device
Version2025r3
LanguageEnglish
On your mobile device, download the free XProtect Mobile app from Google Play or App Store℠.
  1. Find the app in the app store by searching for "XProtect Mobile" and then install it on your mobile device.
    The XProtect Mobile logo icon appears on the screen of your device.
  2. To run XProtect Mobile, tap the icon.
Note
By default, a Milestone demo server is installed. Use the server to test the app. The server is just for testing, so there are some things you can't do. For example, you can't use pan-tilt-zoom controls.
You can't delete or edit the demo server, but you can hide it from the server list. To hide the server, go to Settings, under General, enable the Hide demo server setting.
To view videos from your cameras, connect the app to one or more mobile servers (see Connect your mobile device to a mobile server).
