XProtect Mobile client
Configure user profiles on the server
Version2025r3
LanguageEnglish
You must enable certain user permissions to ensure that users of XProtect Mobile can use access control and view and respond to access requests on their smartphones or tablets. Depending on your VMS, the setup differs slightly.
In Management Client:
  1. Expand Security and select Roles.
  2. Select the role that you want to modify.
  3. In Role Settings, click the Access Control tab.
  4. If not already selected, select these check boxes:
    • Use access control - Required to view access control features in XProtect Mobile
    • Receive notifications - Required to receive access requests as push notifications
  5. For each required role, repeat the steps above.
  6. Save the changes.
