XProtect Mobile client
Select a language for the app
Version2025r3
LanguageEnglish
By default, the XProtect Mobile app uses the language of your device. For example, if your device uses French, the XProtect Mobile client displays in French.
To use a different language, change the language of your device. Then, restart the XProtect Mobile app to apply the change.
Note
To use the XProtect Mobile client in a specific language, your device must support that language.
