XProtect Management Server Failover
Server certificate for the failover web console
Version2026 R2
LanguageEnglish
Note
You can connect to the failover web console over an HTTP or HTTPS connection. This section is only relevant if you want to use an HTTPS connection.
The server certificate is a .crt file that you install on your computer. You must add the certificate to the computer’s “Trusted Root Certification Authorities” store so that your computer trusts that certificate. If you do not install the certificate, your connection will remain secure, but:
  • You will get a security warning the first time you open the failover web console.
  • The system will not trigger an event in case of failover.
You must install the server certificate on all computers from which you want to access the failover web console.
To secure the communication with the failover web console, you need a server certificate. You can let the installer create one for you or use a custom server certificate.
About the server certificate created by the installation wizard
The wizard creates and downloads a server certificate from a local web service while configuring the failover cluster on Node 1. The wizard downloads a new server certificate whenever you configure the failover cluster. You can remove the previous certificates from the “Trusted Root Certification Authorities” store.
If you lose the server certificate, you can download it again from the Manage your configuration page on Node 1. See Generate certificates to access the failover web console.
The server certificate is valid for five years. You will not receive a warning when a certificate is about to expire. If a certificate expires, your browser will no longer trust that certificate. To renew the server certificate, you must configure a new failover cluster.
About using customer server certificates
To use a custom server certificate, see Use custom server certificates for communication with the failover web console.
