XProtect Management Server Failover
Ports used by XProtect Management Server Failover services and modules
Version2026 R2
LanguageEnglish
Service
Default ports
Purpose
safeadmin
Remote access on UDP port 4800
Communicate with other safeadmin instances on other computers. The main and mandatory administration service that is started at boot.
webconsole
Local and remote TCP access on port 9010 to the failover web console
The service is a standard Apache web service that is mandatory for running the web console, the distributed comman-line interface, and the <module> checkers.
Failover cluster modules
The ports values of one module are automatically computed depending on its module ID.
Module
Ports
Purpose
heart
port=8888 +(id-1)
UDP port used for sending heartbeats between the servers.
rfs
safenfs_port=5600 +(id-1)x4
TCP port used for replications requests between the servers.
