Ports used by XProtect Management Server Failover services and modules
Service | Default ports | Purpose |
safeadmin | Remote access on UDP port 4800 | Communicate with other safeadmin instances on other computers. The main and mandatory administration service that is started at boot. |
webconsole | Local and remote TCP access on port 9010 to the failover web console | The service is a standard Apache web service that is mandatory for running the web console, the distributed comman-line interface, and the <module> checkers. |
Failover cluster modules
The ports values of one module are automatically computed depending on its module ID.
Module | Ports | Purpose |
heart | port=8888 +(id-1) | UDP port used for sending heartbeats between the servers. |
rfs | safenfs_port=5600 +(id-1)x4 | TCP port used for replications requests between the servers. |
