XProtect Management Server Failover
Troubleshooting XProtect Management Server Failover
Last Updated: 4 minute read
Version2025r3
LanguageEnglish
System log file
To troubleshoot system errors, you can find the ManagementServerFailover.log file on the computer where you have installed XProtect Management Server Failover at C:\ProgramData\Milestone\XProtect Management Server\Logs.
The configuration of the failover cluster has failed
The failover cluster does not function properly
Cannot remove configuration
The VMS services do not start after removing the configuration
