XProtect Management Server Failover
Step I: Start the configuration on Node 2
Version2025r3
LanguageEnglish
After you have checked the prerequisites and prepared your system, you can start with the configuration of the failover cluster without data replication.
If you have two or more running management servers that are connected to the same SQL Server databases, your data might be corrupted.
To avoid potential database conflicts, before you start the configuration, go to Node 1 and:
On Node 2:
You are now ready to continue on Node 1. See Step II: Continue the configuration on Node 1.
