XProtect Management Server Failover
Start, stop, or restart a node
Version2025r3
LanguageEnglish
You can control your cluster nodes from the failover web console. To start, stop, or restart a node:
  1. On the right-hand side of the node, select the three dots to open the menu.
  2. Select Start, Stop, or Restart. The console refreshes with the expected state.
    Tip
    You can select the three dots next to videoos to apply an action on both nodes.
