Identify the hostname of a node
The failover web console represents the primary computer as node1 and the secondary computer as node2. To see the host name that corresponds to a node:
From the failover web console, click the node you want to see the hostname information about.
Go to the Information tab.
In the Hostname field, you can see your hostname.
