XProtect Management Server Failover
Network and computer prerequisites
Version2025r3
LanguageEnglish
Prepare your infrastructure for the configuration of the failover cluster.
  • Operating system - Install two identical operating systems on Node 1 and Node 2. To see a list of supported operating systems, go to https://www.milestonesys.com/systemrequirements/.
  • Addresses - In the same subnet, assign static IPv4 addresses to the nodes and reserve an IPv4 address for the virtual IP. The virtual IP allows the remote servers to connect seamlessly to the running management server.
    Important
    If the host name and address of a node does not resolve as expected by the system, the configuration might fail. See DNS lookups.
    Note
    Do not assign IPv6 addresses to the computers that run the management server and external SQL Server. XProtect Management Server Failover does not support the IPv6 protocol.
  • Domain or workgroup environment - Configure the failover cluster in an Active Directory (AD) domain or workgroup environment.
  • Time - Synchronize the time and time zones between the nodes.
  • ICMP traffic - Allow inbound ICMP traffic through all device firewalls.
  • PowerShell execution policy - Set your PowerShell execution policy to Unrestricted. This allows the configuration wizard to run PowerShell scripts on both nodes. See about_Execution_Policies.
  • Windows Defender Advanced Thread Protection Service - You must disable Windows Defender Advanced Thread Protection Service. See Disable Windows Defender Advanced Thread Protection Service.
