XProtect Management Server Failover
Change the identity of an IIS application pool for XProtect
Version2025r3
LanguageEnglish
To change the identity of an IIS application pool:
  1. Open the Start menu, and enter inetmgrc to open Internet Information Services (IIS) Manager.
  2. On the Connections pane, double-click your server to expand the list menu, then select Application Pools.
  3. Right-click an application pool that starts with VideoOS and select Advanced settings...
  4. Under Process Model, change the Identity with the selected Windows account.
  5. Repeat steps 3-4 for all VideoOS application pools.
  6. Start all VideoOS application pools.
