Update remote site hardware
Version2026 R2
LanguageEnglish
If the configuration has been changed on a remote site, for example, added or removed cameras and events, you must update the configuration on the central site to reflect the new configuration on the remote site.
  1. On the central site, expand Servers and select Recording Servers.
  2. In the Overview pane, expand the required recording server, select the relevant remote system. Right-click it.
  3. Select Update Hardware. This opens the Update hardware dialog box.
  4. The dialog box lists all changes (devices removed, updated and added) in the remote system since your XProtect Interconnect setup was established or refreshed last. Click Confirm to update your central site with these changes.
