Enable playback directly from remote site camera
Version2026 R2
LanguageEnglish
If your central site is continuously connected with its remote sites, you can configure your system so that the users playback the recordings directly from the remote sites. For more information, see XProtect Interconnect setups.
  1. On the central site, expand Servers and select Recording Servers.
  2. In the Overview pane, expand the required recording server, select the relevant remote system. Select the relevant interconnected camera.
  3. In the Properties pane, select the Record tab, and select the Play back recordings from remote system option.
  4. In the toolbar, click Save.
In a XProtect Interconnect setup, the central site disregards privacy masks defined in a remote site. If you want to apply the same privacy masks, you must redefine it on the central site.
