System Monitor (System Dashboard node)
Version2026 R2
LanguageEnglish
The System Monitor functionality provides you with a quick, visual overview of the current well-being of your system's servers and cameras.
System monitor dashboard window
Tiles
The upper part of the System monitor dashboard window shows colored tiles that represent the state of your system's server hardware and camera hardware.
The tiles change their state and thereby color based on threshold values set under System Monitor Thresholds node. For more information, see System Monitor Thresholds (System Dashboard node). Define the thresholds, so tile colors mean the following:
Tile color
Description
Green
Normal state. Everything is running normally.
Yellow
Warning state. One or more monitoring parameters is above the threshold value for the Normal state.
Red
Critical state. One or more monitoring parameters is above the threshold value for the Normal and Warning state.
Hardware list with monitoring parameters
If you click a tile, you can see the state of each selected monitoring parameter for each hardware represented by the tile in the bottom part of the System monitor dashboard window.
The monitoring parameters for one piece of hardware in the System monitor dashboard.
Example: A camera's LIVE FPS monitoring parameters have reached the Warning state.
Customize dashboard window
Select Customize in the upper right corner of the window to open the Customize dashboard window.
In the Customize dashboard window, you can select which tile to create, edit or delete. When creating or editing tiles, you can select which hardware and which monitoring parameters you want to monitor on the tile.
Details window
If you select a tile and then from the hardware list with monitoring parameters, select the Details button to the right of a camera or server, you can -depending on the selected hardware - view system information and create reports regarding:
Hardware
Information
Management server
Shows data about:
  • CPU Usage
  • Memory available
Select History to see the historical states of your hardware and create a report on the above data.
Recording server(s)
Shows data about:
  • CPU usage
  • Memory available
  • Disks
  • Storage
  • Network
  • Cameras
Failover recording servers
Shows data about:
  • CPU usage
  • Memory available
  • Monitored recording servers
Log servers, events servers, and more
Shows data about
  • CPU usage
  • Memory available
Cameras
Shows data about:
  • Storage
  • Used Space
  • Live FPS (Default)
  • Recording FPS
  • Live Video Format
  • Recording Video Format
  • Media Data Received (Kbit/s)
  • Memory available
Select the camera name to see its historical states and create a report on:
  • Data received from camera
  • Camera disk usage
