Set log retention policy
Version2026 R2
LanguageEnglish
Log retention determines how long logs are stored before they are automatically removed. Each log type has its own retention configuration.
The configuration files are located in: C:\Program Files\Milestone\VictoriaLogs\.
Log type
Configuration file
System logs
VictoriaLogsConfig_System.json
Audit logs
VictoriaLogsConfig_Audit.json
Rule logs
VictoriaLogsConfig_Rule.json
Change the retention period
To change the retention period:
  1. Open the relevant configuration file.
  2. Locate the LogRetentionPeriod setting.
  3. Enter the required duration. e.g.
    "LogRetentionPeriod": "14d"
  4. Save the file.
Supported retention formats
Unit
Example
Days (d)
30d
Weeks (w)
4w
Months (m)
3m
Years (y)
1y
The minimum supported value is 1d. There is no upper limit. Logs can be retained indefinitely, with available disk space acting as the only practical limit.
Retention guidelines
Audit logs are often retained longer to support auditing and compliance requirements.
Log type
Typical retention
System logs
Days to weeks
Rule logs
Weeks to months
Audit logs
Months to years
Warning
Audit logs can contain personal data. If GDPR compliance applies to your organization, consider limiting audit log retention to one year unless a longer retention period is required by law or policy.
