Metadata-related permissions
Specify the following permissions for metadata devices:
Name | Description |
Read | Enables the permission to see metadata devices and retrieve data from them in the clients. |
Edit | Enables the permission to edit metadata properties. It also allows users to enable or disable metadata devices in the Management Client and via the MIP SDK. |
View Live | Enables the permission to view live metadata from cameras in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. |
View live restriction | Enables the permission to view live restricted metadata from cameras in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. |
Playback | Enables the permission to play back recorded data from metadata devices in the clients. |
Playback restricted recordings | Enables the permission to play back recorded data from restricted metadata devices in the clients. |
Read sequences | Enables the permission to use the Sequences feature while browsing recorded data from metadata devices in the clients. |
Export | Enables the permission to export recorded audio from metadata devices in the clients. |
Create and extend evidence locks | Enables the permission to create and extend the evidence locks on metadata in the clients. |
Read evidence locks | Enables the permission to view evidence locks on metadata in the clients. |
Delete and reduce evidence locks | Enables the permission to delete or reduce evidence locks on metadata in the clients. |
Start manual recording | Enables the permission to start manual recording of metadata in the clients. |
Stop manual recording | Enables the permission to stop manual recording of metadata in the clients. |
Create and extend live and playback restrictions | Allows the client user to:
NoteRequires user permissions to all devices included in the restriction. |
Read live and playback restrictions | Allows the client user to:
Delete and reduce live and playback restrictions | Allows the client user to:
