Issue: Adding Active Directory users to roles fails
Version2026 R2
LanguageEnglish
It may not be possible to add a Windows Active Directory user to roles from a Management Client that runs on a different computer than the Management Server.
Cause
This can happen if the Management Server does not have port 445 open for incoming traffic.
Solution
Open port 445 on the XProtect Management Server computer for inbound connections from any workstation running the XProtect Management Client application.
For more information, see ???.
