Install silently using a dedicated service account
Version2026 R2
LanguageEnglish
If you want to install XProtect VMS unattended, you must start the installer with the arguments in the table below. Arguments must be created and saved in an arguments XML file that you generate prior to the installation.
Argument
Description
--quiet
Forces silent installation.
--arguments
The path to the arguments XML file with full configuration. The path could be: C:\Arguments.xml.
--license
The path to the license file.
Using a dedicated service account
This description is based on the use of a dedicated service account for integrated security. The services always run on the dedicated account no matter which user is logged in, and you must make sure that the account has all required permissions to, for example, perform tasks and to access network, files and shared folders.
The service account must be specified in an argument XML file for the following keys:
SERVICEACCOUNT
SERVICEACCOUNT_NONLOC
The password for the service account must be specified in plain text in the value for the following key:
ENCRYPTEDPASSWORD
Example: command line to start the installation in silent mode:
"MilestoneXProtect VMS Products 2023 R2 System Installer.exe" --quiet --arguments=C:\Arguments.xml --license=C:\M01-C01-231-01-ABCDEF.lic
Example: Arguments file based on the use of a dedicated service account
<?xml version="1.0" encoding="utf-8"?>
<CommandLineArguments xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="urn:[company_name]">
  <InstallEnvironment>
    <Parameters>
      <KeyValueParametersOfStringString>
        <Value>true</Value>
        <Key>USERACCOUNT</Key>
      </KeyValueParametersOfStringString>
        <Value>domain\sampleaccount</Value>
        <Key>SERVICEACCOUNT</Key>
        <Key>SERVICEACCOUNT_NONLOC</Key>
        <Value>sampleaccountpasswordplaintext</Value>
        <Key>ENCRYPTEDPASSWORD</Key>
        <Value>%PROGRAMFILES%\Milestone</Value>
        <Key>TARGETDIR</Key>
        <Value>true</Value>
        <Key>IsXPCO</Key>
        <Value>true</Value>
        <Key>IsDPInstaller</Key>
        <Value>false</Value>
        <Key>LEGACY</Key>
        <Value>yes</Value>
        <Key>SQL-KEEP-DATA</Key>
        <Value>no</Value>
        <Key>SQL-CREATE-DATABASE</Key>
        <Value>True</Value>
        <Key>IS_EXTERNALLY_MANAGED</Key>
        <Value>Data Source=server.database.windows.net;Initial Catalog=Surveillance;Persist Security Info=True;TrustServerCertificate=True;Authentication=ActiveDirectoryIntegrated</Value>
        <Key>SQL_CONNECTION_STRING_MS</Key>
        <Value>Data Source=server.database.windows.net;Initial Catalog=Surveillance_IDP;Persist Security Info=True;TrustServerCertificate=True;Authentication=ActiveDirectoryIntegrated</Value>
        <Key>SQL_CONNECTION_STRING_IDP</Key>
        <Value>Data Source=server.database.windows.net;Initial Catalog=Surveillance_IM;Persist Security Info=True;TrustServerCertificate=True;Authentication=ActiveDirectoryIntegrated</Value>
        <Key>SQL_CONNECTION_STRING_IM</Key>
        <Key>SQL_CONNECTION_STRING_ES</Key>
    </Parameters>
  </InstallEnvironment>
</CommandLineArguments>
Prerequisites to be completed prior to performing the installation:
  • The service account as well as the account used to perform the installation must be created.
  • The service account must be allowed to log on as a service on the computer where the installation is performed. See Log-on-as-a-service.
  • The databases to be used by XProtect must be created, and the databases must be named in the arguments XML file, for example:
Database name
Surveillance
Surveillance_IDP
Surveillance_IM
  • The databases must be configured according to the following list:
Database configuration
The default collation must be set to “SQL_Latin1_General_CP1_CI_AS”
ALLOW_SNAPSHOT_ISOLATION must be set to ON
READ_COMMITTED_SNAPSHOT must be set to ON
  • An SQL Server logon must be created for the service account and for the account used to perform the installation in each of the databases. A database user must be created in each of the databases, and the user must be a member of the db_owner role on each database.
