Enter the system configuration password settings (recovery)
Version2026 R2
LanguageEnglish
If the file that is holding the password settings is deleted due to a hardware failure or other reasons, you will need to provide the system configuration password settings to access the database that is holding the system configuration. During installation on your new computer, you will be asked to enter the system configuration password settings.
But if the file that is holding the password settings is deleted or corrupted, and the computer that is running the management server has no other problems, you have the option to enter the system configuration password settings:
  1. Locate the management server tray icon.
  2. Right-click the notification area's Management Server service icon and select Enter the system configuration password.
  3. The enter the system configuration password settings window appears.
The system configuration is password-protected
  1. Type the password in the password field and select Enter.
  2. Wait for the password to be accepted. Select Close.
  3. Make sure that the management server is running.
The system configuration is not password-protected
  1. Select the check box: This system does not use a system configuration password and select enter.
  2. Wait for the setting to be accepted. Select Close.
