Migrerar loggservern
Om migreringen
[en] The log server migration copies existing log data from the log server to VictoriaLogs or your monitoring solution. It does not affect system configuration data and is optional.
[en] If you do not migrate existing logs, historical log data remains in the log server and is removed automatically according to its retention settings.
Migrera loggservern
Medan uppgraderingen pågår:
[en] Components that are not yet upgraded continue to send logs to the log server.
[en] Upgraded components send logs to Server Logs.
[en] Run the migration
[en] On the log server computer, go to:
C:\Program Files\Milestone\XProtect Management Server\Tools\LogServerMigrationTool
[en] Run:
VideoOS.LogServer.Migrate.exe
[en] A console window opens briefly and then closes automatically. No progress information or confirmation message is displayed.
[en] The absence of messages does not indicate an error. The migration tool runs without user interaction.
Efter migreringen
Befintlig loggdata från loggservern är tillgänglig tillsammans med nyare loggposter i Serverloggar.
När du inte längre behöver loggservern kan du sluta använda den och tillåta lagringsinställningar för att ta bort eventuell återstående data.
