[en] Server Logs
バージョン2026r1
言語日本語
注記
[en] This article describes the Server Logs functionality introduced in 2026 R1, which uses OpenTelemetry and VictoriaLogs. If your system uses the legacy Log Server, refer to the documentation for your XProtect version instead.
[en] Introduction
VMSサーバーコンポーネントはXProtect、システムアクティビティ、イベント、エラーのログエントリを生成します。これらのログエントリは、OpenTelemetryプロトコル(OTLP)を介してOpenTelemetryを使用して収集および送信されます。
[en] The OpenTelemetry Collector forwards log data to a log processing service. By default, this is VictoriaLogs.
[en] You can view system logs, audit logs, and rule logs in XProtect Management Client. From the Server Logs page, you can search, filter, and analyze log entries to investigate system activity, user actions, events, and errors.
[en] Some logging settings, including retention and collection behavior, are managed outside XProtect Management Client through the OpenTelemetry Collector and VictoriaLogs configuration files.
[en] OpenTelemetry and the OTLP protocol
[en] OpenTelemetry is an open standard for collecting and transferring telemetry data, including logs. XProtect uses the OpenTelemetry Protocol (OTLP) to send log data between components in the logging infrastructure.
[en] Using OTLP makes the logging infrastructure more flexible. In addition to the default setup with VictoriaLogs, you can connect the system to external logging or monitoring solutions that support OTLP.
OpenTelemetryがログをテレメトリ信号として処理する方法の一般的な概要については、OpenTelemetryドキュメントのOpenTelemetry Logging:https://opentelemetry.io/docs/specs/otel/logs/ 。
OpenTelemetry Collectorサービス
サーバーログには、実行中のOpenTelemetry Collectorサービスが必要です。サーバーコンポーネントはXProtect、OpenTelemetry Protocol(OTLP)を使用してログをコレクターに送信し、コレクターはログをVictoriaLogsまたは外部のログソリューションに転送します。
[en] The OpenTelemetry Collector receives log data from XProtect server components and forwards it to the configured log processing service. By default, this is VictoriaLogs.
[en] VictoriaLogs
[en] VictoriaLogs serves as the log database engine for XProtect logs, handling log storage, querying, and analysis. It replaces the SQL Server-based log database used in earlier versions of XProtect.
[en] You can access log data from the Server Logs page in XProtect Management Client.
[en] By default, system logs and rule logs are retained for 7 days, and audit logs are retained for 30 days. Older log entries are automatically deleted when the retention period expires. You can modify the retention settings in the VictoriaLogs configuration files stored on the Management Server. For more information, see Set log retention policy.
