View effective roles
Version2026r1
LanguageEnglish
With the Effective Roles feature, you can view all roles of a selected user or group. This is practical if you are using groups and it is the only way of viewing which roles a specific user is a member of.
  1. Open the Effective Roles window by expanding Security, then right-clicking Roles and select Effective Roles.
  2. If you want information about a basic user, enter the name in the User name field. Click Refresh to display the roles of the user.
  3. If you use Windows users or groups in Active Directory, click the "..." browse button. Select object type, enter the name, and click OK. The user's roles appear automatically.
